SailNet Community - View Single Post - hinge oem - anchor locker
post #2 of Old 10-24-2004
Jeff_H
Moderator
Jeff_H's Avatar
In the early 1980''s, I think that Oday used a lot of ''Tops-in-quality'' hardware.''Tops-in-quality'' is a Canadian company. You might try them. They also used Merriman which was in its death throws at that point. You should be able to find a set of hinges of the same physical dimension and then either fill the bolt holes in the boat with thickened epoxy and drill new holes or if the bolt locations are extremely different, (i.e. no overlap between the old and the new hole) then drill new holes in the hinge.
Jeff_H is offline
