SailNet Community - View Single Post - West System Pumps.
post #8 of Old 03-03-2009
sailingdog
5200 is not a replacement for epoxy, and IMHO shouldn't even be used on a boat. 5200 has too strong an adhesion strength for anything that may need to be removed at some point in the future, and you should probably be using 4200 instead.
Epoxy is really a structural material, and should be used to do things like attach stringers to the hull, fill small voids or holes, etc. However, epoxy has one major caveat to it. It must be painted or coated to protect it from UV degradation. Epoxy breaks down under UV...
Originally Posted by Suberk View Post
looks like MAS is a little more pricey, but it you don't have to buy thickener for West... so when would i use epoxy as an adhesive, rather than 5200? Any pros, cons?
sailingdog is offline
