Really bad idea IMHO. You don't want the freshwater fill and the head pumpout any where near each other. Many pumpout fitting will spray a bit...
and do you really want raw sewage anywhere near your fresh water deck fill????
If you have a leaky o-ring or forget to close it tightly, what do you think the chances of getting sewage into your potable water tank is if they're located next to each other???
Originally Posted by jaschrumpf
This might be a possibility: leave the freshwater fill as is. In the anchor well I could cut another hole next to the freshwater fill and drop a weighted line down where I can pick it up inside the v-berth access panel. The I could use a fish tape to reach over from there to where the holding bladder is.
Once I've done that I could attach a line to a piece of sanitary hose, pull it over to the access plate, attach it to a fitting, pull the fitting up through the hole with the line and then fasten the fitting in place from above.
Voila! A new deck fitting for the pumpout. If there's room I could even double up and pass a vent line up that way along with it.
Have to stick my head back down there this week and have a look-see about this.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
