SailNet Community - View Single Post - atomic 4 damage?
post #6 of Old 03-04-2009
CalebD
Tartan 27' owner
CalebD's Avatar
The situation sounds bad but do not give up hope.
We had a flood in our cabin 5 years ago that got water in the engine oil. I won't divulge the reason for a the flood while on a mooring but suffice it to say it was salt water and nearly 6" above the cabin sole (floor). This was high enough for some water to get into the dipstick hole. Our engine wasn't completely flooded, plus it was summer so no freezing.
After removing the water from the cabin the engine started right up. Later, we checked the oil and found a milky color. Uh-oh! After a call to Don Moyer (see link previously posted) I went and changed the oil in the engine 3 times and each change came out clearer and clearer. Last oil change I put in Rotella T SAE 30 but for the quick oil changes I used cheaper oil.
Our engine is over 40 years old and is still ticking. I hope you have similar results.
Everybody has one:
CalebD is offline
