Originally Posted by jaschrumpf
There is no other deck fitting location. There is a pumpout fitting now in the v-berth under the cushions and the freshwater fill in the anchor well. I figure I can either swap the usage of the fittings or drill a new hole so they can both be up in the anchor well.
Oh, I thought it was in the deck above the v-berth.
My bad... I'd still want the two fittings further apart.
If the pumpout guy gets confused as to which is which and accidentally attaches the pumpout to the water fill.. that would be bad. I've seen it happen, and it's not pretty.
I've seen accidents like that happen with water and fuel, fuel and pumpout, pumpout and water, etc... Keeping them physically separated by some distance is the cheapest insurance against mistakes. BTW, it takes forever to get rid of the taste of diesel once some gets in the water tank...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
