SailNet Community - View Single Post - Catalina 22 mast light disconnect question
post #13 of Old 03-04-2009
geraldartman
I replaced that on my C22 2 years ago. Although my problem started with the fixed assembly being rotted and you couldn't fix the wires with the set screw so I never got a good connection. I remember replacing the unit with a 4 pole but just using the existing wire ends. I did rewire the mast using the diagram in the users group list which showed mounting a two way switch on the mast with up lighting one and down lighting the other. Simple and easy to reach with the pop top up or down.
geraldartman is offline
