Hi John,
I'm glad you think this information is helpful and I truly hope it is. The only reason I post and do a blog is because I myself have spent so much time trying to learn from other people and feel I should do my part.
I am using the 195 degree for now because even with that she runs a steady 190 degrees. From all I can read this is well within the safe margin for continuous operation and I am hoping to burn off any accumulated carbon that might be removable. As long as she stays around 190, I see no reason to change. Again, between our 45 degree water and my efficient cooling system, there is virtually no cause for concern about overheating as she never budged above 160 before.
I suspect that with the 180 degree thermostat that she would run between 175 and 180, which is at the lower limit of fine, but after her being run 700+ hours too low in temperature, I am anxious to run her at the upper margin of things.
The CarQuest part # for the 180 thermostat is: 31978
Hope this helps.
Aeolus
Gulf 32
Bainbridge Island, WA
