Clucas—
The simplest way to do this is to eliminate the sink drain seacock and diverter valve at the sink. There's no reason you can't drain the sink through the head intake seacock. If you want to flush the sink using fresh water from the head, just close the seacock. This is actually the method suggested by Peggie Hall, diva of marine heads and plumbing.
That said, what you've drawn is basically how my head sink is setup, excep there's no seacock on the sink drain, since it drains above the waterline, by about two feet, and there's little risk of heeling to submerse it on a trimaran.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
