SailNet Community - View Single Post - Newbie glassing over a thru-hull
post #9 of Old 03-06-2009
jonb
Glassing over a small thru-hull
I have a need to fill in a 3/4" hole remaining after removal of a thru-hull.
Would the technique for a filling a smaller hole still require a 1/12 taper on the outside of the hull?
I was planning to use multiple layers of glass cloth on the inside of the hull where there is a recess for the thru hull (where there is no core). I was thinking of using milled glass fibers to fill the hole itself and have a very small taper of maybe only 1" around hole again filled with the milled fibers.
Is this sufficient or should I be using glass cloth on the outside of the hull with a larger tapered area.
C&C 44
Kingston/Lake Ontario
jonb is offline
