SailNet Community - View Single Post - I didn't want a project but but I have one
post #2 of Old 03-08-2009
sailingdog
A previous owner had drilled holes through the exterior skin and plugged with epoxy. This did nothing except place little stalagmites of epoxy throughout the cabin top.
THis is why I say re-coring the area properly makes far more sense than trying to drill and fill with thickened epoxy.
Before doing anything else, you have to figure out where the water that rotted the core came from and deal with that. You really do need to replace the entire core, because, the chances of core material drying out once saturated is almost zero.
I would recommend re-glassing, not re-using the pieces you've cut away. The reason for this is simple. The longer and more continuous the glass fibers in a laminate are, the stronger it will be.
I'd use end-grain balsa for the new core, as it is lighter than plywood, and doesn't have the disadvantages as a core material that plywood does. I'd also recommend tapering the core material and putting solid glass at any points you have deck hardware coming through the deck.
sailingdog is offline
