Thread: Wifi
  #15 (permalink)
Old 03-08-2009
sailingdog sailingdog is offline
JRD—
That's basically an amplified high-gain directional antenna with an integrated ethernet bridge. It basically converts a wifi signal into a Cat5 ethernet connection. It provides about a 10 dB gain in signal strength and gives about 60˚ of horizontal coverage, which is usually good enough for most boats at anchor to use—and easily well within the capabilities of covering a boat in a slip.
The advantage of doing this is that there is no signal strength lost due to having a long antenna cable. It is pretty simple to power it off the boat's DC system, since it operates on 12 VDC. Also, you only need to run a single cable, since the unit uses Power Over Ethernet to power itself.
Available here for $80 or so.
