Spring onsluaght on 473
Ground down a few rust spots on the keel and painted bare iron with por15. Refaired with west system and redid barrier coat in those areas. New anode and grease job for the max prop 3 blade classic. New cutlass bearing. Resealed Mast partner and did an IRAN on the mast and foils. Still decideing on whether to remove the poli-glow the PO had on it or just freshen it up. Just ordered 4 new lifeline AGM's (ouch). New Wrap stop head piece on forestay as old one was spinning. New shroud roller end pieces to prevent rattling ordered. Starting to understand Syselios a little better now. Paying close attention to the systems used for furling as the boat came with some rather expensive North 3dl cruising sales. Found a runner and a reacher below and they look almost unused. My sail maker convinced me to add a sock and a snuffer. As always, appreciate any advice or observations.
Marc
