Blu,
I think when we do the big cruise it is going to be very much with a shoestring approach perhaps similar to yours.....Like I said in my above post we have a modernised and slightly modified 'Pardey' approach.
We currently have a 27 footer, yet are members of club where most of the cruising folk are retiree's in 40-50 footers. We sometimes get the reaction you talked about as well, but most of them are pretty welcoming and aren't much worried that we are slumming around with them in our little boat. Alot of them started themselves in similar sized boats.
I think Sailnet is pretty similar, I don't think there is a fight to be had here Blu. No one here has ever judged me for the size of my boat or the style of my sailing here.
I also think Cam made a very good point earlier as well....
Originally Posted by camaraderie
As I read these threads with the theme "go now...go small...but go" I think about all the cruising couples we've come in contact with over the last few years and it seems to me that the vast majority of the boats that I will call "campers" have packed it in. Some because the money ran out, some because it wasn't fun anymore and some because one of the two said "enough".
Living on a small boat at anchor for extended periods of time requires a LOT of adjustment and most couples are not up to it. It is tough enough on a larger boat. Interestingly, I see a lot of single guys on small boats that have been doing it for a while and seem happy enough.
OK...I'll get to my point. If you are considering living aboard and cruising, it is easy for the dream to obscure the reality. I think you have to be very realistic about what level of comfort and inconvenience you can put up with for years on end. If you are not honest about this with yourself, you will end up unhappy and with a short cruise. There is a huge difference for a couple living aobrd a 40+ foot boat with complete systems and going off on a 30 footer. It costs a lot more to buy AND live aboard the larger boat so that means delaying cruising or adjusting the duration planned if 40'+ is what will work for you.
None of this is to say "don't go small"... just be sure you BOTH can handle it. I do subscribe to the theory of GO as soon as you are able to do it in the manner which will make you happy!
I guess its simple, most of us spend what we can afford to spend at a level that provides an acceptable level of comfort.
Having said that.... Could we all benefit from toughening up a bit?? Probably
