SailNet Community - View Single Post - Who says I don't know JACK?
post #10 of Old 03-09-2009
Wayne25
Wayne25's Avatar
David:
Can you hand sketch a section of the hull deck joint? I see where the deck overlaps the transom in your picture and is screwed or through bolted as I can see the heads of the screws under your epoxy. But I'm not sure what happens down the sides of the boat. Most manufacturers either have mating flanges turned in or turned out. Ours don't seem to have that. I don't know if the 1/2"x3" horizontal rib is part of the hull or deck. I would assume the hull. If so, does the deck turn down and overlap the hull (like the transom) and rest on the 1/2"x3" rib? The hull then should turn back up after the rib about an 1" to make the joint. Is that rib solid glass or just a turn in the mold of the hull?
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
