SailNet Community - View Single Post - Wifi
Thread: Wifi
post #20 of Old 03-09-2009
dsiddens
Making Ready
dsiddens's Avatar
Dock
Drakus' WiFi
WISP Router (wisp-router.com) sold me a RooTenna and an Engenius C3B for about $200. The antenna has about 19dB of gain and space for the C3B radio to fit inside. There is very little signal loss when the C3B (the radio portion) is at (inside) the antenna. The antenna is described as directional but it does have a fairly wide sweet spot. It takes 12vdc power and outputs ethernet connectivity. Ethernet hookup means easy connection to your machine.
Specifications:
Parameter
Min
Typ
Max
Units
Frequency Range
2400
2485
MHz
Input Return Loss (S11)
-14
dB
VSWR
1.5:1
Impedance
50
OHM
Input Power
20
W
Operating Temperature
-45
+70
Deg C
Gain
19
dBi
3db Beam Angle (E-Plane)
15
Deg
3dB Beam Angle (H-Plane)
20
Deg
Front to Back
30
dB
Weight
9 (4.1)
Lb (kg)
Compartment Dim (L x W x H)
16.25 x 14.75 x 2
(413 x 375 x 50)
Inches (mm)
Outside Dim (L x W x H)
18.5 x 16.8 x 4
(470 x 427 x 102)
Inches (mm)
Wind Loading
100MPH
125MPH
100MPH with Radial Ice
Force (Lbs)
77.8
121
83
ECB-3220 below. This is the higher power, 400mW, new improved version. This is what goes inside the RooTenna, sans rubber ducky.
Darn, I've got this stuff below and don't know how to delete it. Suggestions welcome. Doug
dsiddens is offline
