SailNet Community - View Single Post - Removing Head Help on PSC 37
Old 03-09-2009
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
Jay,
My hunch is those are screws rather than bolts, and they are turning without backing out because the plywood base/core under the fiberglass is not what it used to be.
You may be able to get a flat edge under the head of the screw/bolt and see if you can pry it up a bit. If it comes easily, then grab with a vice grip and complete the extraction.
I hope my hunch is wrong, but if not, you'll need at a minimum to pot those holes with a epoxy and re-tap them before remounting the toilet. Hopefully there is enough solid core left in there.
Good luck- John
