You're really better off crimping for several reasons. First, making a proper solder joint is much more difficult than making a good crimp with a good crimper. Second, solder tends to create hard points which are far more subject to fatigue-related failure on a boat. Third, in an extreme case, the solder can heat up in a short situation and leave a hot wire exposed, since solder is not considered a mechanical connection—this can't happen with a properly crimped connection.
