SailNet Community - View Single Post - Centerboard Winch Cable
post #2 of Old 03-10-2009
knothead
Some of the one's I've worked on have a hole that the wire feeds through and then a Nicopress stop sleeve is crimped on the end.
Others have a hole and with an intersecting hole for a set screw.
Sometimes it can be difficult to feed the wire through the hole. A trick that may make it easier is to wrap impregnate the wire with superglue and wrap it tightly in the area you are going to cut it before cutting it.
knothead is offline
