SailNet Community - View Single Post - Diesel versus propane
post #2 of Old 03-11-2009
sailingdog
Why would you scrap a perfectly good propane heater? They're not really dangerous if properly installed. They're also quite efficient. Propane is also a much cleaner fuel than diesel is.
The problem with using a diesel stove/heater combo unit is that IIRC, it is not vented. It will introduce a lot of moisture into the boat, since it doesn't have a chimney/exhaust. It also runs a slightly higher risk of carbon monoxide poisoning.
Also, diesel stoves, IIRC, have to be pre-heated, so you'd need alcohol aboard the boat to pre-heat it with.
sailingdog is offline
