SailNet Community - View Single Post - Small Leak in Cabin Roof
post #7 of Old 03-13-2009
sailingdog
Silicone caulk has no place on a boat other than bedding certain types of ports and covering the ends of cotter pins. 5200 has almost as few uses on a boat IMHO. It has far too tenacious a grip and is a pain to unbond if you ever have to remove the hardware in question.
Sealing leaks from beneath is a really, really bad idea, since that can trap water inside the hole and lead to serious problems like the core penetration and delamination. Generally, deck fittings on a sailboat should only be sealed from the outside, so that any leaks are fairly apparent and visible on the inside.
3M 4200 is good, SikaFlex 291 is good, butyl tape is good, but it depends on what you're sealing.
sailingdog is offline
