Yes, that's the beauty of using the NS2—you don't have to muck with the WIFI settings on your laptop, since it uses the ETHERNET card. Just disable the WiFi card when you're on the boat, and when you go to the internet cafe, just re-enable the WiFi card.
Originally Posted by scosch
You read my mind SD. After reading your prior recommendation, I was thinking about getting one of those for use at anchor near, but not quite near enough, to a wifi source and was wondering about hooking it up.
After reading your directions here, which I think I can implement ok, I wondering if I will need to reconfigure my computer next time I DONT want to use this device, say when I take the computer to a local cafe with readily available wifi. Will the laptop's separate built in wifi receiver and the ethernet plug used for this device work independently without switching all my settings back and forth? (Sorry, this may be obvious but theres a lot to learn about this stuff)
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
