Yes, Garmin uses the 12 VDC GROUND for their signal ground... if the radio's NMEA in (-) isn't connected to the Garmin's Black Ground wire, it won't work.
Be aware that the Ray54 VHF only has limited DSC capabilities in that it only has NMEA IN, and does not have NMEA out. Better DSC radios have NMEA out as well so that the position of boat's using DSC, like those in an emergency, can show up on your plotter screen.
