SailNet Community - View Single Post - Voltage Drop
Thread: Voltage Drop
post #1 of Old 03-16-2009 Thread Starter
rayncyn51
Voltage Drop
I am replacing the wiring harness in the mast. I have a tri-color and anchor light at the top (both LED), and a steaming light and some hefty deck lights at the spreaders. I've done a ton of research about voltage drop. I've found and used many of the tables referenced elsewhere here in Sailnet. It appears that if I follow the reccomended guage for AWG marine grade wire to achieve the suggested maximun 3 percent voltage drop, I would be adding roughly 10 pounds of wire in the mast. Compared to what has worked for the last 30 years, wiring that big seems a bit excessive to me. I would like to hear some thoughts about what works in the real world. Thanks in advance. - r
Are we there yet?
rayncyn51 is offline
