SailNet Community - View Single Post - Protecting PVC Dinghy?
post #4 of Old 03-18-2009 Thread Starter
night0wl
night0wl's Avatar
Originally Posted by midlifesailor View Post
For lifting, I recommend a trick picked up from an older cruising couple at our marina assuming you have a windlass. They attach a block the spin halyard and lead a line through the block to the windlass. Raise the halyard to position the block about 10-12 feet above deck height and attach the running end to your dink's lift harness, then use the windlass to lift the boat to the deck. Works pretty neat and the two of them get their RIB on the foredeck with little strain to eithers back,
Good Luck.
Wouldn't have thought about that trick, thats just great! I do have a Windlass, but I leave my anchor chain on it most of the time. What type/strength of block are they using for this purpose?
night0wl is offline
