Old 11-17-2004
elhanley elhanley is offline
elhanley is on a distinguished road
General purpose pumps
Depending on how much fuel you need to remove, and how much time you have, the cheapest way is to use your engine''s fuel pump. Just disconnect the discharge end and rout it to a container, then turn the ignition on without starting the engine. You could also use the fuel return line.
