SailNet Community - View Single Post - OMG my boat leaks!
post #6 of Old 03-19-2009
KeelHaulin
STARBOARD!!
KeelHaulin's Avatar
To me, it looks like someone tried to replace the window inside the plastic frame. Since the other windows are crazed and this one is not; it also seems plausible. So what they did was cut the plastic frame off of the old window; install new lexan and then tried to re-bond the lexan to the old frame with silicone. The gap you see is where they cut the frame be able to remove the lexan.
These windows with a plastic surround are usually made at a factory that injection molds the frame material around the lexan; so that it seals perfectly around the window and there are no seams. It's not just a simple matter of slapping in a new piece of lexan when the plastic crazes.
Your best bet for getting it repaired properly is to buy a new portlight from a company that makes them like Mark Plastics in Corona, CA. (IIRC)
KeelHaulin is offline
