SailNet Community - View Single Post - Running Backstays
post #6 of Old 03-19-2009
paulk
paulk's Avatar
Sounds like they're worried that the mizzen won't stand up to a staysail. Instead of pelican hooks or a tackle setup, I'd be inclined to use a hyfield lever. You don't use a staysail all that much, and the hyfield lever will take less room and look neater than the 3:1 line setup. It's not like you're trying to adjust the mizzen mast's curve with a running backstay, which is why you'd want a really adjustable arrangement. With a hyfield lever, it's either on or off, and you're done. The pelican hook setup might have been a bit too loosey-goosey. KISS.
paulk is offline
