Pharm, as per your question, I'm asuming you want to replace the bulbs only. I'd recommend you to change the entire fixture in the case of anchor light. Fixtures designed for LEDs does have a matched lens that makes the range spec the same. I'm also assuming your steaming/deck is the combo Perko or Aquasignal, in these cases, there is no replacement for your deck light as LED are not that strong (you might have a halogen 50W). The steaming light usualy are feston ones, but suggests you might be running your engine, minimizing the advantage of low amps LED. So, I'd rather go for a new anchor light project only ....
Nave Rara
Beneteau Oceanis 43 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
