Originally Posted by OrioninHawaii
Okay this is a weird problem - I liveaboard a 48 ft 1986 celestial ketch.
Well maintained.
The heads are all electric flush (12 V) the forward on has a holding tank and the aft head has a lectrasan.
We have a force 10 propane stove with a trident gas control panel.
Whenever the stove is on and either toilet is flushed it flips the solenoid and shuts the stove off.
I have had two electricians check it out while working on other jobs and they cant find a thing. They are supposedly on separate circuits.
It's not life threatening. Only irking. I have almost decided to attribute it to galley ghosts.
Could it be frequency interference?
Anyone have a clue?
Hi disconect stove 12vdc supply and negative
run temp wire positive and nagative from isolated batt and try again
if this wil fix your problem then
1- you have back feed trough negative
2- 12Vdc solenoid fluxulation max off 10% if this is higher or lower solenoid will rattle or change status
3 measure voltage to solenoit when you flush 10% variation will rattle solenoid
Good luck let me know
Lynger
