Thread: 12v lights
  #13 (permalink)
Old 03-22-2009
timebandit's Avatar
timebandit timebandit is offline
timebandit is on a distinguished road
If your batteries are charging then Check your meter using your car battery to see if it is accurate.
Originally Posted by TonyInNewportOregon View Post
On the topic of chargers and lighting, I'm was an electrician in the Navy and should know this, but don't:
My first night on my boat (last December), I checked my charger because ... well, long story full of problems. The point is, my 120-12 volt converter is putting out amps, but the voltage output is only 10 volts. I don't understand: in order to charge the batteries -- which it does seem to be doing -- doesn't the voltage output have to be greater than that of the batteries, which varies at times between 12 and 14 volts?
Am I an idiot ... or a big idiot?
My other related question on lighting is this: I am a liveaboard and need more lighting. Should I install 120 volt since I am always on marina-paid shore power when in port; or should I install more 12 volt so that, when sailing, I can use it? Advise anyone.
TonyInNewportOregon
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
