Gulftex—
I would recommend hauling the boat.
The problem is that to remove the shaft log hose and replace it—you have to disconnect the propshaft at some point, so you can pull the old hose off and put the new one on. If you have a problem at that point... you don't have the time to solve it if the boat is in the water, since water will most likely be pouring into the boat at that point.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
