Old 11-26-2004
WHOOSH WHOOSH is offline
WHOOSH is on a distinguished road
J-40 for Long Distance Cruising ?
D, there''s another way we can look at the J40 if we''re willing to ignore the price issue. For a 9 ton boat (fully loaded, provisioned & equipped), it''s fast, easily sailed and with a functional layout that''s open, airy & suitable for a tropical environment. As Jeff suggests, when prospective buyers compare it with other 40 footers, they may find storage and tankage significantly smaller and they may wonder where they''ll be putting their huge collection of systems & add''l hardware. But when compared to most 8-9 ton boats, it''s probably a better performer while carrying the same load, and more comfortable as a home.
And so we once again get to the nub of the issue, which is more about you, what you want out of the boat (performance vs. systems/cabins/tankage), and where you intend to do your cruising. If you can live comfortably on 100 amp/hrs/day, avoid the 5 gal. shower and invest the time and effort to provision thoughtfully and without carrying along the butcher shop from back home, this boat is more than adequate to the task re: volume. It may just cost more than many 8-9 ton boats.
Jeff brings up a good question about the rudder and its bearing & structural set-up, and as I recall GYRPHON had to replace their bearing while in SoPac waters. All these boats with spade rudders can see a huge loading at sea in a blow. I''m not sure how feasible it is to strengthen that further, altho'' a call to TPI and/or J Boats would be a good idea if you get serious about this boat.
Jack
