A4 starting #@*&!!+!!#
Thanks guys, I do have a good spark. The engine is very dependable except for when the boat has sailed, usually heeling which makes me think there is a air leak allowing fuel to drain back or conversely the carb is flooding.
There is a manual fuel **** on the line from the tank, no solenoid. I hope to sail on Sunday if predicted weather is good, clear and mid 70's. If so I will try the fuel "off" while sailing theory and turn it back on when I want to run the engine. I am also thinking I should go ahead and replace the fuel line from tank to Racor while I have access to tank.
Thanks again.
