SailNet Community - View Single Post - Boat, Semi, Crane, #%$^@
post #8 of Old 03-25-2009
c40eb
Vikingsailor
c40eb's Avatar
Originally Posted by wind_magic View Post
That sounds like a good course of action. I am a few hundred miles from the closest marina, but I think talking to someone who does this for a living is a very good idea. One of my worries with the stands, besides getting them set up to hold the boat and not fall over, of course, is that the ground may not be the best for holding the boat, it is just a field. I assume I need to prep the site before even considering putting a boat on stands, so that probably involves gravel, or some concrete pads, etc, that is the kind of thing I need to figure out I think. I'm too far away from the coast to even consider putting the boat into an established yard to work on it, the drive would be too far and I wouldn't get anything done.
I've had our boat on dirt/hardpack...and used good sized wooden pads under each leg of the stands. Probably would not be a good idea in soft ground with mud potential. Got to keep an eye on washout and adjust the stands every once in a while to make sure they're tight.
It's not whether you're paranoid...it's whether you're paranoid enough.
s/v Cloudman
1988 Sabre 30
c40eb is offline
