Promise to let us know
what you end up finding, Scott.
Taking the carb apart is no biggie. If you can get it off you can fix it. I don't think fuel additives would work in your case. Nothing I know of will restore that rubber tip on the needle.
I think you might be on to the heeling thing also. It ain't gonna help.
One thing you might try before taking the carb apart, is to take the boat out and get the engine to cut off like it tends to, and then tap on the bowl with an 8 pound sledge hammed. NO NO just kidding, use a screwdriver handle or somthing like that. If the float is stuck it just might dislodge it. Another place to check, is the bowl itself. there is a screw on the bottom of the bowl loosen it and see if gas comes out. If it does we know we have gas all the way to the Carb.
Good luck and please let us know what you find
Fair Winds
Dave
