SailNet Community - View Single Post - davits for hans christian
post #2 of Old 03-26-2009
kaluvic
kaluvic's Avatar
I've posted some of these pics before, so sorry to those have of you that have already seen them.
I ran my davits thru the aft deck into the floor of the lazarrette
The 4inch SS vertical pieces have a solid diaphragm inside to prevent kinking where the pass through the deck (inside nylon sleeve)
They can be rotated out of the way for heavy weather passages.
There is a take-up drum in the elbow for a 2in webbing strap.
The idea is to lift the dingy out of the water with conventional blocks/line then pass the webbing from the end of the davit where its always attached....under the dingy and the tail end into the winch drum
then crank it up until the dingy is sandwiched tight up under the davits.
James S
S/V Arctic Lady
kaluvic is offline
