Old 03-27-2009
mightyhorton mightyhorton is offline
mightyhorton is on a distinguished road
Thanks, guys. Good info. Spill pipe. Sounds like whatever you can invent that will stay stuffed into the spill pipe will work. My though about removing the anchors from the bow was the same as SD's - lots of weight on the very pointy end of the boat, more surface area for water to torque on........ More applicable on longer passages further from shore, maybe not if you might have to duck into an anchorage. At what point do you decide to lash the anchor down tightly in the bow roller, if you aren't going to remove it? Mine has a nice beefy pin and the usual dog on the windlass, but there is plenty of room for it to slam around if the bow is getting pounded.
Ian
