Thanks for the great information which I will be putting to use shortly. I have 2 questions.
1. How would you deal with a 6" wide, dark blue painted strip on a white hull? The painted strip is about 3" down from the toerail. Would you tape if off and do it separately or could you compound it at the same time as the topsides?
2. I bought a Makita 9227C. Would you recommend getting the 3M-05711 Hookit™ SBS Compounding Pad to use with the hook and loop backup pad that comes with the Makita? Or would you suggest getting the 3M-05710 Mandrel Adapter and using double sided compounding pads such as a 3M-05703?
Thanks for the help.
