Old 03-30-2009
eherlihy's Avatar
eherlihy eherlihy is offline
Will work to sail. :-)
eherlihy will become famous soon enough
No, the meter will read up to 10% on a dry deck from the moisture in the air, and moisture that should be in the Balsa or marine ply.
I use my meter to detect changes in the moisture readings as I slide the meter over the deck and hull. I wipe the deck with a cotton cloth as I slide the meter along to remove dirt, or any surface moisture (even on a dry day). When the meter reads over 20% that is a good indication of excessive moisture in a cored deck or hull.
- Ed
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
