Old 12-05-2004
kcoffey kcoffey is offline
kcoffey is on a distinguished road
How to Replace Cutlass Bearing?
How can I replace the cutlass bearing on my 1985 Najad 343? There is a bronze fitting on the external end of the tube through which the prop shaft passes. No doubt, the cutlass bearing is inside this bronze fitting, but I cannot see any apparent way to remove the fitting or otherwise gain access to the bearing! Also, from where can I get the rpope new bearing part. Thank for your advice!
