The real key is what is the bottom in the location you'll be using it in. If the bottom type is wrong, you won't be able to use a helix mooring. I would also highly recommend that you talk to the company about the usage and the loads your boat will impose. While 32' LOA is a relatively small boat, yours is relatively heavy for a boat of that size.
