SailNet Community - View Single Post - Mast base organizer?
post #6 of Old 12-12-2004
geohan
Re deck trackage. Would tweekers (Downhauls floating on the jib sheets to judiciously positioned deck blocks) answer your need? If the eye pads were ''inboard'' and ''outboard'' (inhaul & outhaul) you can trick the jib clew into thinking its fairlead was any place within a rectangle on deck. The higher the clew the longer the fore and aft dimmension of the rectangle. However, a fixed fairlead further aft would be required to provide a fair lead to the winch. It''s an economical and convienent way to position the jib clew for sail shaping.
FWIW, George
geohan is offline
