Electrical draw problem
When I turn my Shur Flow water system on the lights dim and then flicker as the system comes back up to pressure. This system has a dual filter and a pressure tank so at the end of each pump cycle it works fairly hard to pressurize.I would like to know if I go to a larger wire size will this go away or is it a common problem I should just deal with. Do you think this is a drop on the whole board or what. I gusee it would be if it causes the cabin lights to dim.Could it be all the way back to the batteries and should I put a meter on to see if it is. ?????
