SailNet Community - View Single Post - Spreader bracket compression tube frozen
post #9 of Old 04-05-2009
knothead
Originally Posted by US27inKS View Post
I would guess that the hole on the bolt head side is large enough for the compression tube to slide out. If you drill out the rivets on the bracket you should be able to remove the bracket and bolt together. If this is not the case, I would vote for cutting the bolt head off and enlarging the hole to slide the tube out. Trying to hammer or press the bolt through will likely damage the mast before the bolt comes out.
I agree. That's why I suggested
Originally Posted by Knothead
I would recommend that you get it down to the bare spar, clean up all the corrosion and then decide how to proceed. You should probably replace the bolt and compression tube anyway so you don't have to worry about damaging them in the process of removal. Just don't damage the mast too much.
I have a feeling it may come out.
knothead is offline
