SailNet Community - View Single Post - WiFi - Onboard Internet & Networking Your Boat
  #22 (permalink)
Old 04-06-2009
sailingdog sailingdog is offline
The Linksys would be only necessary if you wanted to: 1) provide an on-board wifi network for multiple laptops to use...2) connect multiple devices with hardwired-Ethernet to the WiFi network.
A good use of the first one is to provide other boats without a long-range WiFi antenna setup access to the WiFi network you're bridging.
A lot of newer nav hardware, like Garmin's higher end chartplotters, radar, etc., are ethernet equipped and need to be networked.
Originally Posted by pschoonveld View Post
Hey sailingdog,
Ubiquity's site wasn't terribly helpful, but I saw mention elsewhere that the NanoStation could run as a bridge or a repeater. Why would you need the LinkSys if it can run as a bridge.
I've been thinking about something like this for a bit and it looks like Ubiquity has a ton of options.
