I'd recommend you read this
primer on solar power on boats I wrote.
Then you need to figure out what your rough daily electrical usage is, and how many days of electricity you'll be using. That gives you a rough estimate to base your battery bank on, and then figure out how many days you have between uses....and that gives you your rough recharge time. Base your solar panel sizing on the recharge time and the amount of power you need to replace, but give yourself a bit of a safety margin—20-25% would be good.
Originally Posted by netscheid
I have a West Wight Potter 15 with a 12volt battery in it. I want to keep it charged out on the water as I will be listening to music and having a few lights on this summer. What would you recommend for keeping it charged. Solar or wind power? And are there any cost effective ways because solar panels are usually very expensive. I also am wondering how much a solar panel can do considering I may be using the battery a lot. Do you think it could keep up with my use and how many watts would it need to be to do that? Thanks.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
