SailNet Community - View Single Post - Spreader bracket compression tube frozen
post #10 of Old 04-08-2009 Thread Starter
donlofland
Smile Success!
So here's how I did it, thanks to all your input!
I cut off the thread end of the bolt close to the mast, ground it flat, center punched it and then drilled end on into the bolt until that end no longer met the inside wall of the mast, (using a 5/16" bit into a 3/8" bolt). Then I turned the mast over, cut the head off the bolt, and did the same from that side. It fell off into the mast and I fished it out.
Thanks again!
donlofland is offline
