  #13 (permalink)
Old 04-08-2009
sailingdog sailingdog is offline
This is not necessarily true, since you have to account for the cost of maintenance and replacement of the diesel charging source. If you take those factors into account, solar and wind are both far more reasonable. Also, if you're cruising long-term, diesel charging sources have a problem of having finite fuel—which solar and wind charging systems do not. With solar and wind charging systems, you don't have to carry the fuel with you.
Originally Posted by mawm View Post
The best advice I got when looking for a way to keep the batteries charged out on the water was that diesel is a lot cheaper than buying solar panels or wind chargers. I have 2x 80ah house batteries (which gives me about 60ah usable power) and a separate starter battery, my alternator is old and puts out 28amps (!!!). I run the engine (18hp - uses 1litre an hour) 2x a day for 1hr to cool the freezer and charge the batteries - but then I don't have a lot of electronics, just a gps/depth sounder, vhf and an auto tiller. I have put in LEDs on some lights, but have kept incandescent for the rest as they are much 'warmer'.
I guess that I make up the shortfall of amps at times when I'm motoring and at the marina I keep a trickle charger attached. It is cheap and works for me.
