Deck/Steaming light wiring question
I bought an aftermarket Deck/steaming light for the mast of my Catalina 22.(with no directions) There are two wires neither of which are marked coming out of the deck light.(one of them the ground (not sure which)having the ability to run into where the steaming light connections are.)There are three screw connections inside the lens for the steaming light two of which are connected to the same spot on the receptacle. I bought the wiring harness from Catalina direct which supplies me with three wires at the correct location on the mast.(White, Green and Black)Can someone guide me as to which wires go to which locations? I am under the impression I will be running these lights at different times so they will be on different switches. I also may add I bought the upgrade breaker panel for the cabin so I have plenty of options. Thank You, Andy
