SailNet Community - View Single Post - Splicing anchor rode
post #9 of Old 04-10-2009
sailingdog
The Octo-plait or eight strand braided is a good line with a lot of beneficial characteristics for an anchor rode, and usually not significantly more money than the three-strand laid line. It doesn't have a tendency to hockle as does the three-strand, and it flakes far more compactly, which means you can store the rode in a smaller space. Windlasses handle it well, and many windlass manufacturers recommend it for their rope/chain gypsies, and it can take a good chain-to-rope splice so it feeds through the gypsy well.
As I said previously, you can get pre-spliced rodes at a reasonable price with G4-high-test chain pre-made. You do have to inspect the splice for wear regularly, but other than that and rinsing it with fresh water, they don't require much maintenance.
A good woven chafe protector is a necessity. The reason I like the woven chafe protectors is that they help prevent the second major reason for anchor line failure—heat buildup due to internal friction—which the plastic/rubber hose chafe protectors can cause. The woven ones let water through to cool and lubricate the anchor rode, helping prevent heat buildup.
Originally Posted by MtHopeBay View Post
Ok. I hear you. In that vein, then, do I go with the conventional 3 strand twisted nylon, which looked like the low cost option, or is there a better cord for anchor rode that might cost me a little more?
sailingdog is offline
